Marks Web Site
Date:  2-21-2009
Number of Hours:  3.00
Manual Reference:  11-x
Brief Description:  Engine to firewall ground cable installation...
Another day of odds and ends. I started by drilling and riveting an anchor nut onto the firewall for the engine to firewall ground cable and then bolting on the cable. This was followed by the installation of the starter cable clamps, one on the forward oil sump flange and one on the right hand side. Lastly I installed the support clamp for the cabin heat valve control cable and drilled the hole for the cable pass through through the side of the cabin heat manifold.
Engine crankcase to firewall ground cable
Starter cable clamping
Cabin heat control cable clamp
